2640 Tie Rod
Old Hickory
11-05-2001 20:06:35
I need to remove the tie rods on a JD early model 2640. Would appreciate it if someone could tell me what size pickle fork to use.
Roy
11-06-2001 06:19:17
 Re: 2640 Tie Rod in reply to Old Hickory, 11-05-2001 20:06:35
Russ has the right idea, but if you are having to replace them use the larger fork, the small one is just a little too tight.If you need replacements, email me I'll give you a good price,Roy.
Russ
11-05-2001 20:15:00
Pry on the tie rod and smack the arm with a big hammer and it should fall down or out after a few good hits. I work as a JD tech and this also saves the rubber cup
