JD plow
Brian
11-05-2001 10:38:19
I have a JD plow no.55 A-B-H anyone know about what year it could be. I would also like to paint it. Are the older implements a different shade of green or the same.
Bob Collins
11-06-2001 05:41:58
 Re: JD plow in reply to Brian, 11-05-2001 10:38:19
Brian, Your plow was labeled 55A-B-H but that was John Deeres way of covering all the variations. If it is equipped to be raised with a hydraulic cylinder, then the "H" is correct, if it is a 12 or 14" rice plow then it uses the "A" and if it is the clutch lift 12, 14 , or 16" regular plow it is a 55B, with hydraulic lift it would be a 55H. Anyway if it is hydraulic and has a leveling crank instread of a lever it was made prior to 1949. Later ones used the lever just like the clutch lift models which also had a master lever for depth control. If yours has rubber tires, originally they used 16" tires, but after 1952 the size was changed to 15" A few hours in parts catalog PC178 available from JD will maybe allow you to get a bit closer with the year of build. Bob
Brian
11-06-2001 10:56:51
 Re: Re: JD plow in reply to Bob Collins, 11-06-2001 05:41:58
My plow is a 16" with levers for height adj. and 15" rubber tires. I'm going to try to find a parts manual to pin piont a year. I know it must be mid 50's from your description. I would like to thank you for the info.
Stan - florida
11-06-2001 11:48:13
 Re: Re: Re: JD plow in reply to Brian, 11-06-2001 10:56:51
You can order a Parts Catalog, PC524(01DEC60), by calling 1 (800) 522-7448.
Stan
Brian
11-13-2001 10:30:41
 Re: Re: Re: Re: JD plow in reply to Stan - florida, 11-06-2001 11:48:13
Stan thank you for the number i'm going to call them
Stan - Florida
11-05-2001 12:15:54
Late '40s to early '50s. Color is most likely the same as the tractors from that era. What would that be? Depends on who you're asking.
Stan
