What year is my A
A guy
11-04-2001 06:28:31
just bought a slant dash A and i cant makeout the second number on the tag. Its a steel tag and its gitting rusty and would like to get a new tag .It starts with a 5 and what looks to be a 3 witch would be a 1944.It has a cast frame with a draw not like the old loop style.a 1944 would have a steel tag.any thoughts would help.thanks for now
Will P
11-04-2001 18:23:23
 Re: what year is my A in reply to A guy, 11-04-2001 06:28:31
The cast iron frame was for the second half of the 43 model year and all of 44. The steel tag is also used for 43-44 war tractors. The 44 A was built to 542699. The 43 A was built with the angle iron frame at first, then Deere killed production for the war for 5 months. When they started to build the 43's for the second half, they put a cast iron fram on it. I don't have my info on when they started the cast iron frame right now. But I will find it. Hope this helps. Oh, the 44 year started with 524423. YT mag site is wrong with the serial numbers.
Will P.
A guy
11-04-2001 18:38:53
 Re: Re: what year is my A in reply to Will P, 11-04-2001 18:23:23
I seen on other slant dash question you say your from wi.Im from southeastern Mn not far from la cross.
Will P
11-04-2001 19:22:18
 Re: Re: Re: what year is my A in reply to A guy, 11-04-2001 18:38:53
The cast iron frame was used from serial number 522600-542699. It had a pressure cooling system from serial number 523600-542699. hope this helps more.
Will P in Burlington.
