670A JD Grader
Bowd
11-03-2001 18:23:21
Help on trannie on 670A JD Grader ? on taking pinion out without pulling final drives & splitting back in half?
david val
11-04-2001 08:15:51
 Re: 670A JD Grader in reply to Bowd, 11-03-2001 18:23:21
transmission in jd graders is actually the agriculture power shift transmission. that means that in order to remove the pinion, the ring gear with differential should be removed first. since there is no room above the transmission ,i think it must be removed from the machine.
david
