60 rear wheels
Kevin
11-29-2003 03:28:17
I just bought a 53 Model 60 and I'm trying to move the rear wheels in.(to fit on my trailer better) According to the shop manual I loosen the three bolts, and move the jack bolts in, raise the wheel and then use the rack screw. Well there not budging... The jack bolts won't go in to the second line as per the manual. The rack bolt won't turn. I loaded them up with PB Blaster but they only sat a short time, do I need to be more patient...They probably haven't been moved in years... Thanks for any help, Kevin
luckydog
11-29-2003 08:27:04
 Re: 60 rear wheels in reply to Kevin, 11-29-2003 03:28:17
Kevin-If you can find a old wedge from the same axel with the spline, lay it on the axel and beat on it rather than on the bolts. You get a more evenhit with a hammer and it saves your bolts. luckydog
Ron
11-29-2003 08:00:27
When I find one with a stuck wedge, I turn the wheel so penetrant can be poured into the "Corked hole", and light the old Blow Torch and let it heat for one Hour... refilling the oil in the hole as needed.. I have the 3 big bolts out, too, and put penetrant in there, too. THEN, I use a 3/4" breaker bar, WITH a 4' pipe extension, Get the jack screws ( You DID grease them? ) TIGHT, then use a large drift-pin and a 6LB hammer, placed exactly on the "Key" portion of the wedge..it should Jump out..!!
720Deere
11-29-2003 05:46:26
Not to be redundant, but I have alot of experience with these and Clooney is absolutely right. PATIENCE is the key. I have found that when the pinion is stuck that complete removal of the wheel makes the job alot easier. Heat is almost a must, but be careful as that wheel is cast iron & can and will break. (Can be easily replaced if it is a F1500R, but not if it is a window pane) Nine times out of ten that stuck pinion will drive out before it will turn. I prefer to remove it anyway so that a complete clean and lube can be performed. Good luck to you and remember patience is key, that thing didn't rust up overnight!
John51
11-29-2003 05:37:37
The key here is PATIENCE! Soak them with Blaster and rap them good every once in a while. I'm assuming you have already loosened the bolts that hold the hub in. Screw them back in almost all the way and rap them hard. How about the ones on the inside? If you can get them loose and out you can remove the wheel (CAREFUL!) and lay it down to get the Blaster into all the crannies where it needs to go. I've had some that took a while but eventually all came free for me.
Good Luck
Clooney
11-29-2003 05:34:03
Kevin, I'm not exactly sure from your post if you can turn the jack screws at all,,, or if you just can't turn them in to the line?
~IF, you can turn the jack screws in at all just turn them in as tight as you can,, then drive the tractor around the barn & use the brakes sharply & even try forward then reverse then jabbing the brakes. You might try tightening the jack screws more as you drive it.. Do one side at a time & don't go far.. That usually breaks the collars loose..
~Now if you still can't get them loose, do the same thing only loosen the inner 3 wedge bolts on the other side of the wheel.
~If you can get them loose but the rack adjusting bolt still won't move [turn],, remove the complete inner wedge, then turn the wheel so the rack gear is pointing down, then either slide the wheel where you need it or pull the entire wheel off [you will have to work it off] so you can heat the pinion gear & bolt & work some penetrating oil around them.. There is a CORK that you can pry out on the non bolt head side that will allow penetrating oil to added to that side.. You will still probably need heat on the gear & shaft.. In real bad cases of rust you will need to heat the gear & shaft , then drive the gear shaft [the one with the bolt head on it] out from the cork side using a long drift & hammer..... ..
~Post back with any questions..
[email protected]
Mark Scholten
11-29-2003 05:31:21
Don't be afraid to smack the head of the bolts to jar them (or any rust) loose. Use a three pound hammer or there abouts. No sledge hammers please. Soak them with whatever is available. I was told once upon a time that water will break the rust loose because that's what caused it. A big torch is helpful also. Get the area around the bolts hot, and I mean hot, then douse them with water. When they get hot, they expand some,(even cast moves) then douse them with water until you can put your hand on it. As you may see, this is a 3 step process. As your patience wears thinner and thinner, you move to more aggressive means.
Good luck, let us know how you came out.
Mark Scholten, Sparta, Michigan
Roger
11-29-2003 04:58:21
Kevin, I'm new at this but just got finished moving the rear wheels on a 50 (the same) I tried everything to get those jack screws to move from all the penetrants, time, and heat that i could muster. Finally I had to break them off, drill them out, etc. and put in new jack screws. I hope you have better luck than I did. Lots of patience and fun.
cole in mo.
11-29-2003 05:31:34
 Re: Re: 60 rear wheels in reply to Roger, 11-29-2003 04:58:21
this is what you do. jack up the wheel, completly remove the (3) bolts holding the wedge, replace them with (3) different bolts, leaving them about one inch from contact. then smack each one a good rap with sledge hammer, the wedge will move in. back off the jack screws. then if the ratchet is still stuck, turn the wheel so that the rack is on the bottem, use a long pry bar under the tire and slide the wheel in,the wedge will bind but just tap the three bolts as you shove it inward. when you get it where you want it, just tighten the 3 bolts. the reason for using different bolts is so the heads of the orig. won't get battered up. I used an impact wrench to loosen the ratchet. hope this help you.
Dan
11-29-2003 06:05:48
 Re: Re: Re: 60 rear wheels in reply to cole in mo., 11-29-2003 05:31:34
Kevin, read cole in mo's post and do what he says. I worked on my 50 for a month this summer doing the other things posted here. When I turned those three bolts out about 3/4 of an inch from the hub then rapped them with a 3 lbs. hammer the wedge came right out. Forget about using heat or driving on those wheels to break them loose, unless you enjoy going through the whole spectrum of emotion with a sledge hammer in your hand.
Kevin
11-30-2003 10:59:21
 Re: Re: Re: Re: 60 rear wheels in reply to Dan, 11-29-2003 06:05:48
Well their moved.... The first side the ratchet worked, the other side I had to remove the wedge half and slide it. I found out my rims are filled and heavy.....I didn't need any heat, three cans of oil and bent two breaker bars and broke one 1/2" ratchet, and melted 1/2" electric impact. Need to beef up the tools...I want to replace the rims with a new aftermarket set when I change the tires(weathered to far)Any suggestions for a supplier(rims)?Thanks to all who responded... I wouldn't had a clue without all the help!!!
Thanks again
Kevin
