Need Experience on Coil/Distributor
John
11-03-2001 10:52:48
I am wanting a hotter spark in a model A JD. I have a high voltage coil. My question is: I have heard that by increasing the points gap in the distributor, a hotter spark will result. Is this so? The standard points gap is .015-.020. How much should I open the gap?
RUSS
11-05-2001 20:12:13
 Re: Need Experience on Coil/Distributor in reply to John, 11-03-2001 10:52:48
Go to your local automotive store and get plugs 2 numbers hotter than what is recommended. This works well in Nebr where it gets cold in the winter. This has always worked for me.
Bill from up north
11-03-2001 20:41:33
As far as I know changing the point gap will do nothing to alter coil output voltage but it will advance your timing so be careful with that.
Bus Driver
11-04-2001 09:10:31
 Re: Re: Need Experience on Coil/Distributor in reply to Bill from up north, 11-03-2001 20:41:33
Increasing the points gap will decrease the spark intensity. The dwell time would be decreased. Use the least points gap with which the tractor runs well. This will require frequent adjustment of the points as wear on the rubbing block decreases the point gap. For those wanting minimal maintenance, when installing new points, use the largest point gap recommended by the tractor manufacturer. This maximizes the running time before adjustment is needed.
