For JD 4000's
Steve II
11-03-2001 07:30:30
Does any one know what the L - LD1 - LD2 - D on the lower right of the seat in tractor is that something to do with the 3 point? I could't find my book so I am out in feild working. thanks
Deere Jon 2000
11-03-2001 09:04:15
 Re: For JD 4000's in reply to Steve II, 11-03-2001 07:30:30
I'll be guessing a little here because I'm working with a 4010 that has only 3 settings: L, L&D ,and D. These settings are to allow different reactions of the 3-point to equipment like a semi-mounted plow, chisel plow, rear mount blade, brush hog ,etc. In the L (Load) position, the 3-point responds to the engine speed, when the engine pulls down, the 3-point is raised to reduce the load and then returns to the depth set when the engine regains it RPMs. In the (D) Depth position the 3-point responds only to the depth setting. In the L&D (Load & Depth) position the 3-points combines the two inputs (rpms & depth) to maintain both a more constant depth and engine RPMs. My guess is that L&D1 is more responsive to the load that the depth and L&D2 is more responsive to depth than to the load.
Steve II
11-03-2001 09:49:23
 Re: Re: For JD 4000's in reply to Deere Jon 2000, 11-03-2001 09:04:15
Great, Thanks.. I doing some dirt work like that where the dirt is kind hard and never been worked in, That's what I doing now..
