JD 60 Rear Tire Size
Mike S
11-02-2001 17:42:09
I have a JD 60 with 14.9 X 38 tires and the rims are 11 X 38. The tires are good but the rims have rusted out around the valve stem and need replaced. These tires seem big for the rims. What size rims should I buy to work with the tires I have?
G Taylor
11-02-2001 22:16:28
 Re: JD 60 Rear Tire Size in reply to Mike S, 11-02-2001 17:42:09
The "ideal" tire size for an 11" rim is 12.4x38. As the rims are rotten the time & money to repair the old ones is better spent on new rims. Link has new rims in common & odd sizes for anything with wheels. www.millertire.com is a fine dealer to work with & prices are respectable for rims & tires. Is this a working tractor, parade tractor or used for pulling in tire restricted classes?
Mike S
11-03-2001 06:43:12
 Re: Re: JD 60 Rear Tire Size in reply to G Taylor , 11-02-2001 22:16:28
I use this tractor to pull a manure spreader. Thanks for the information.
G Taylor
11-05-2001 22:43:55
 Re: Re: Re: JD 60 Rear Tire Size in reply to Mike S, 11-03-2001 06:43:12
For a working tractor FireStone radials win every time. They pay for themselves with reduced fuel usage & improved crop yields due to less soil compaction. Even when run dry the tractor will pull more than loaded tires. If more ballast is required a few external cast iron weights are preferred.A dry tire pulls more than a wet tire.
Mike in Mo
11-02-2001 20:11:01
The manufacturer's recomended width for a 14.9 is a 13" rim. I put mine on a 14" rim because thats what I already had, and they look good on that size rim. Mike
