3010 Gas
Gary
11-01-2001 18:45:44
Been a mechanic for years but this one is stumping me today. Put in accel diaphram and needle and seat.Points recently new,new cond.,freed up the mechanical advance that was stuck. Runs good at idle and wide open,but under load up a hill for instance, pulling,it runs out of power in about 500' and dies. Starts up again and will go the same till it has to pull like in 8th gear.Had the carb. apart three times to readjust the float and clean and check everything. Plenty of fuel from the pump,and even hooked up an aux.tank right to the carb.to try something.Like it can't get the fuel into the carb fast enough and sucks it dry,then dies and will then restart after a little cranking????? ? Any thots or past experience on one like it?
J.Nolan
11-02-2001 17:41:49
 Re: 3010 Gas in reply to Gary, 11-01-2001 18:45:44
My 3010 did the same thing and I even ran a new fuel line where engine heat would not cause vapor lock. No luck. Turned out to be the fuel inlet into the carb had a screen that was covered with almost invisible varnish. Scrapped it off and opened the screen holes and it ran great.
Lee
11-02-2001 03:07:19
There may be a screen filter on the last fitting where the gas line goes into the carb. I know there's one on my 420.
Steve II
11-01-2001 19:05:47
There should be a little filter under the gas tank needs to be cleaned.. and check line from tank to pump and to carb..
