Aftermarket hydraulics on a D
Mark Scholten
11-28-2003 19:06:41
I picked up the aftermarket hydraulics for my '47 "D". Put everything on but it doesn't develope any pressure. I think I need to bleed the air out of the system but I ran out of time. Also, there is a small lever on the hydraulic pump. Does this disengage the pump? If so, what is the proper position? I am leaving for Dallas in the morning and won't be back til wed. night so I have a few days to think about what I need to do. Thanks for any suggestions or resolutions.
Mark Scholten in Sparta, Michigan
37D
11-29-2003 05:43:47
 Re: Aftermarket hydraulics on a D in reply to Mark Scholten, 11-28-2003 19:06:41
I take it that you have one of the hyd pumps that mounts behind the mag. If so you COULD be air locked, but more than likely the drive lug in the pump is worn out & slips under load. Yes the lever is a shut off & if anyone tried to engage the pump while the engine was running it would surely strip the drive lugs. For my own use & whenever I rebuild one of these, I machine a solid drive coupler & eliminate the shutoff entirely. Seems to work much better than the original & doesn't change the outward appearence at all, you just remove the internal shifting parts, install the solid coupler & leave the lever intact.
Donny-B
11-29-2003 06:14:47
 Re: Re: Aftermarket hydraulics on a D in reply to 37D, 11-29-2003 05:43:47
37D, Do you have a John Deere manual number for these pumps? I have one that I am going to install on my 47 D and would like to have operating/parts/service manuals on the unit. Also I am looking for an installation manual (or copy) for the same. Thanks, Donny-B
37D
11-29-2003 07:31:46
 Re: Re: Re: Aftermarket hydraulics on a D in reply to Donny-B, 11-29-2003 06:14:47
Forgot to add, these hydraulic systems are basically the same as on an "AR-AO", (except for the pump location of course, & the hyd lines). I have a line on a guy that MIGHT have an old original shop bulleten describing just how to install the hyds on a "D", I haven't contacted him yet but will soon, as I also have a hyd kit for my styled "D", & want to do it right the first time. If you can find the manual for an "AR", it would likley answer many questions.
37D
11-29-2003 07:21:07
I don't have a manual for this, only the instruction sheet that came with a seal kit I got from John Deere several years ago. By the way these seals are available at NAPA at about one third the cost from "Mother Deere". When I got the kit, I went straight to NAPA & crossreferenced them & bought a couple extra sets. I could look up the #s, but would have to go to the shop to check. I have some things to do right now & a funeral this PM, but if you need the seal #s, post back & I can get them later this afternoon.
Donny-B
11-29-2003 18:04:29
 Re: Re: Re: Re: Aftermarket hydraulics on a D in reply to 37D, 11-29-2003 07:21:07
37D, Any info on the seal cross ref would be appreciated. Also if you can locate a copy of the service bulletin I would pay for a copy + postage. I would like to do a factory type installation rather then guessing how to hook it up. You can Email me with a response. Thanks, Donny-B
