Model R Diesel project
Bill R
11-28-2003 19:06:07
Don't really post often but read regularly. About a month ago pulled the "R" in the shop for what was supposed to be a quick radiator core change. When everything was off the front I thought it would be nice to pull the head now ( I knew it had a freeze crack in the lower part ). Called about a head, the place had one on the shelf, all they had to do was assemble it. (Does anyone know what JD gets for $$ on the copper injector sleeves!!) Took the injectors to the diesel shop, rebuilt both, tonight I took the injection pumps out because the gasket under them was leaking, trying to decide whether or not to take them to the diesel shop. Got the gasket set from JD. also resealing the transfer pump. I will have to say that I was pleased with the cylinder walls and pistion conditions. No questions so far, but when reinstalling those pumps I'm sure there will be. Just wanted to let everybody know what going on with the "R" Lot more money spent right now than I intended, but the sound of a good starting and strong running 2 cyl diesel working out in the field where it is supposed to is priceless.
Bill R
A // B // GW // R Diesel
Tony M
11-30-2003 06:36:08
 Re: Model R Diesel project in reply to Bill R, 11-28-2003 19:06:07
I have replaced the injector tubes before, and didn't think it was too bad. Just follow the manual's suggestion and thread a 7/8" tap into the top and pull the old one, then press the new one back in. Be forewarned, if the diesel shop does not have a machine specifically for two-cylinder pumps, then can't calibrate them. The injectors follow the basic bosch design and are the same as rebuilding a Mack, Perkins, etc, but the pumps are another story. If they don't have the machine, you may be better off to just put them back on. Watch to see if fuel is leaking out the rear of them while the engine is running to see if they are worn, if not just run them. If I can help in any way, just email.
Tony
gpwtboy
11-29-2003 05:39:21
on the copper inj. tubes, are they hard to change on a model r, and how do you go about changing them,on my jd model r, i think one of the tubes is leaking, any info. will help. good luck with the r, and they do sound good.
Bill R
11-29-2003 09:00:06
 Re: Re: Model R Diesel project in reply to gpwtboy, 11-29-2003 05:39:21
gpwtboy, I think they are pretty hard to change, they are prseed into a blind hole in the casting, the shop that is doing the work on the head is changing mine for me, so i don't really know what it involves.
Bill R
G-MAN
11-29-2003 05:20:50
About $240 for the sleeves, correct? I guess that's just one of those items where you have to grit your teeth and be glad that you can still get them.
