JD D Torque Values
Gino
10-30-2001 18:00:37
Hello, I will be reassembling a 1936 JD D engine and need to know the torque values for the head-to-block, connecting rod-to crank, block to tractor, and block- to-crank. Your help is appreciated. Thank you, Gino
Dale W.
11-01-2001 08:57:27
 Re: JD D Torque Values in reply to Gino, 10-30-2001 18:00:37
Gino, my book doesn't list a torque value for block to case, I think I would use the same as head to block. What I can give you is hesd to block...208 ftlbs Rod caps....100 ftlbs. I hope this helps you out. Dale
