Early-styled B Crankshaft
ryan
10-30-2001 14:47:43
I'm trying to figure out how to time the crankshaft with the camshaft on my B. I can't find any marks on the crank but there is one on the camshaft. Thanks in advance.
Norman
10-31-2001 16:25:48
 Re: Early-styled B Crankshaft in reply to ryan, 10-30-2001 14:47:43
Ryan, I looked today and found out what to do.
Now, if I can only explain myself.
I have the bloke off two tractors. They are unstyled "B"s. You didn't say what year yours is.
The timeing mark on the cam is on the inside. Center punch mark on the valley. So your mark on the crank will be on a tooth. ( I can't find a mark on the crank either) With the bloke off you can really see it. With the left cylinder ( # 1 ) journal all the way back, the part of the crank that you can see as it turns towords the flywheel side, there is a kinda flat spot in the casting. Right there, is the tooth that messhes with the one on the cam. If you turn the # 1 jounal staight down it will be right on top.
If this doesn't get it, you can call me and I will really confuse you. (505) 388-2131 Later
Norman
Fred - CT
10-30-2001 18:57:45
Ryan, I have the service manual for early styled A & B. It says the following: "If flywheel is properly installed turn until "L.H. Impulse" is aligned with mark on gear cover. Then turn governor shaft until groove in magnito or distributor drive coupling flange is horizontal and mesh gears." I did mine (Model A) last winter and this worked for me. Good Luck!!
Norman
10-30-2001 17:41:40
Ryan, I have one torn apart and I will look tomorrow and figure out something for you.
Maybe some one will beat me to it. Later
Norman
