620 clutch
Scott
10-30-2001 08:35:44
My cousin has a 620 with a slipping clutch. All the discs and springs are new. Does not "snap in" like other JD's I've driven. If you adjust it so it snaps, it won't release. I am new to working on larger JD's. Thanks in advance to all who respond.
DP
10-31-2001 09:33:42
 Re: 620 clutch in reply to Scott, 10-30-2001 08:35:44
Scott, most likely the dogs and toggles are needing replaced. It is very hard to see how much these are worn without the new ones to compare with. Also check that the dowel and ear that it slides through are in good shape while you are in there. Good luck, Don
Chuck
10-31-2001 04:46:06
there are parts within the clutch, forks and ball joints that can be worn and broken. You'd need to remove and check...barring this an important part is the double lined clutch plate and the sliding disc....you should look at these items for wear and tear...the double faced disc is pricy at the dealer and so is the disc...but these are very important for good service...
