JD 1120 PTO?
Jack M
10-29-2001 13:09:30
On my JD 1120, the pto will not stop running even when the pto is out of gear. Someone told me it was the hydraulic brake not working, my question is, can it be fixed easily?
Robert
10-29-2001 20:15:39
 Re: JD 1120 PTO? in reply to Jack M, 10-29-2001 13:09:30
Not an easy fix, you must split between transmission and clutch housing. Rockshaft cover has to come off the transmission case, then the bearing support must come off the front of the transmision case, the gears,collars & washers must come off the counter shaft before the bearing support can be removed. The PTO brake band is on the back side of the bearing support.
A LOT of work to replace a $35 part.
John Henry
10-29-2001 15:37:43
Ayup, thats correct. When you shut the pto off the brake automaticaly applies.( live independent pto only) The use of an overunning clutch on tools like brush hogs will greatly extend the life of the pto brake. Keeps the brake from stopping the blades momentum upon disengagement.
