Im an idiot
andy
10-28-2001 14:39:21
the exhaust pipe going from the manifold to the stack is done for on my 36 B there are holes coming through and i want to fix it but when I tried to get it off it wouldnt come i got it so i couldsee up it but it wouldnt come any further and am i jusyt doing it wrong or do i have to replace the stack and all?
Dan
10-28-2001 19:49:23
 Re: im an idiot in reply to andy, 10-28-2001 14:39:21
If you haven't goptten a new one you might check, on my 1938 G JD doesn't make them anymore. Had to get an exhaust guy to built it. luckyly most of it was still there for a pattern
Clooney
10-28-2001 17:33:15
Andy, there is probably a rust or carbon ring formed inside the muffler that keeps the pipe from coming out. You might have to cut the pipe in half about 6-8" from the muffler then remove the muffler & pipe together then use penetrating oil and or heat to remove the pipe.
andy
10-29-2001 17:27:56
 Re: Re: im an idiot in reply to Clooney, 10-28-2001 17:33:15
thanks when im done getting the mag back together right ill have to do that
