Hot 2020
Matthew
11-28-2003 16:04:08
I have a 2020 gas, runs fine when I mow. I recently put a 48 quick-tach loader on it and it runs hot when I mow with it now. I'm going to check a few things on my own, but any suggestions on what to look for will be appreciated.
John
11-29-2003 14:36:05
 Re: Hot 2020 in reply to Matthew, 11-28-2003 16:04:08
Heres a long shot guess. If you are using an independent loader control valve on the loader, make sure its of the closed center variety. I suspect the extra load ofpumping oil thru an open center valve is sapping horsepower and also raising the engine temperature. If you using your remotes to operate the loader then your problem could be elsewhere.
