Gino, you asked where would be the best place to begin troubleshootign for a no spark condition, and that would be (AFTER YOURE SURE THE PLUGS AND WIRES ARE GOOD BUT NEITHER FIRES): PS If you like I can e mail you a 40 Wirign Diagram plus my two Green Magazine articles that explain the whole ignition system, but hopefully the troubleshootign guide below will get you going without near as much info. 1) If you remove the plugs but have their wires attached and their sides firm against the tractors iron for a ground and turn her on and crank her over, do both produce a good visible blue spark???? A faint thin wimpy yellow one???? or no spark at all??? 2) If neither sparks, remove the coil wire out of the distributor cap (leave coil end in coil) and place its exposed end to within 1/8 away from the tractors iron frame or block somewhere, turn her on and crank her over, and see if you get a spark from the coil wire end to the frame????? If so, but not out the plugs, either the plugs or plug wires or the cap and rotor are suspect. Try different wires and plugs to see if when you replace the coil wire into the cap and hook up the plugs, they will fire then??? If still not, remove the cap and look for cracks or carbon traces or moisture and inspect the condition of the inner brass and plastic and the rotor tip for proper installation and not broken. ALSO inspect the condensors wiring and the wires to the points, cuz no wires there or the condensor CAN NOT BE SHORTED OUT, IT KILLS THE SPARK!!!!! !!!!! !!! NOW IF THERES STILL NO SPARK AT ALL, EITHER OUT THE COIL WIRE OR ANY PLUGS::::::::::::::: PROCEED AS FOLLOWS a) Insure voltage is getting to your ignition switch INPUT BAT terminal (usually from the ammeters load (non battery) side or the LOAD terminal on 4 wire Voltage Regulator. A test lamp or voltmeter there will show if battery voltage is present. It (switches input BAT terminal) should be HOT all the time cuz it cant switch on the ignition or lights etc if it dont have power to it. CHECK ANY FUSES AHEAD OF THE SWITCH, A BLOWN FUSE MAY BE YOUR SIMPLE PROBLEM?? b) Insure the ignition switch IGN OUTPUT is HOT indicating voltage when you turn her to ON. Thats the wire from the igniiton switch IGN output down to the coil via any in line series ballast resistor if it has one. c) MOST IMPORTANT When you turn the ignition switch ON, the coils lil high (not to distributor) side terminal has to be HOT to power the ignition. If its not, hot wire it by running a live hot battery feed direct to the coils high (not to distributor) side and see if you have spark then. d) Insure the condensor is good, not shorted, and no wires to it or the points are shorted out. A SHORTED CONDENSOR CAN KILL THE SPARK!!!!! !! You have to have voltage down to the coils high side via the ON IGN ignition switch output terminal and wire (and any ballast) before you can produce spark. Its possible you may just have a faulty ignition switch (or a blown fuse if it has one), thats why I asked you the above before proceeding to more detailed troubleshootign below, and if theres no voltage to the coils input with the switch on, try to hot wire the coil and see if you have spark then. Its also possible IF THE VOLTAGES ABOVE ARE ALL PRESENT, the points may be oxide coated or not openign on high cam to the proper gap or burned or pitted. INSPECT THE POINTS FIRST TO INSURE THEY ARE BOTH CLEAN AND SHINY, NOT OXIDE COATED OR BURNED OR PITTED, AND REPLACE AND GAP IF NECESSARY BEFORE PROCEEDING BELOW. MAKE SURE NO WIRES TO POINTS OR CONDENSOR ARE SHORTED OUT. IF THE SWITCH CHECKS OUT AND THE PLUGS AND WIRES ARE GOOD, BELOW IS A PREVIOUS TROUBLESHOOTING GUIDE I CUT N PASTED TO SAVE ME A TON OF TIME, ALTHOUGH SOME OF IT MAY PARTLY REPEAT THE ABOVE, WHICH I PUT FIRST IN CASE YOU JUST HAVE A BAD SWITCH OR FUSE OR PLUGS, WIRES, OR BAD POINTS OR A SHORTED CONDENSOR. a) If the plugs do spark some (even if faint thin yellow) but the plugs appear fouled or all black or oily etc., first try a fresh set of plugs and see what happens. b) If you get no spark out of the coil wire to 1/8 from ground or none out any plugs, since its so easy to check, remove the cap n rotor and inspect the ignition points for proper gap and that they are opening to that gap when the engine is rotated and the points come up on high cam. If they are opening and gapped right, inspect them (their 2 contact surfaces) and if burned or pitted or carboned up or gray oxide coated, REPLACE AND RE GAP THEM and see if she sparks then. c) If no spark out the coil wire or plugs and the points are gapped and clean and opening on high cam, do the following: 1) Take a test lamp or voltmeter and place it on the coils high (not to distributor) side lil terminal and turn the ignition on and THERE MUST BE VOLTAGE THERE. If not, the ignition switch or a fuse in the dash or switch may be blown. SHES NEVER GONAN FIRE UNLESS THERES VOLTAGE ON THE COILS HIGH SIDE. TRY TO HOT WIRE THE COIL IF THE SWITCH IS BAD, SEE IF SHE SPARKS THAT WAY. 2) If there�s no voltage on the coils high (not to distributor) side when switch is on, run a hot wire from the ungrounded battery post or starter terminal (known good voltage source) direct to the coil (hot wire it) and crank the engine and see if she sparks. If so, suspect a bad ignition switch or a blown fuse feeding it. Look at the switch and use a test lamp to see if it has a hot wire feeding its input (from ammeters load, non battery side or LOAD terminal on a 4 wire VR) and if turned on the wire leading to the coil becomes hot. 3) If there IS VOLTAGE on the coils high side, place the test lamp over on its low (to distributor) side lil terminal and have ignition on and crank the engine over slowly. The test lamp should flash On (when points open) and OFF (when points are closed). a) If lamp never goes off: Points are bad (burned pitted carboned) or not closing or there�s a poor ground connection between body of distributor and tractor. b) If lamp never comes on at coils distributor side: Coil may be bad (open)or the condensor is bad (shorted) or the points or spring or a wire on or to points or condensor wire is shorted. If you simply remove the condensor and then she fires, the condensor is shorted or its wiring TEST THAT!!! SHES NEVER GONNA FIRE UNTIL THERES VOLTAGE ON COILS HIGH SIDE (maybe a bad switch or fuse or broken feed wire) AND A LAMP ON ITS LOW SIDE FLASHES ON (points open and coil good and condensor or points wiring not shorted) AND OFF (good points close and distributor grounded).
SUMMARY, first check the plugs for fouling and replace if necessary,,,,, ,,,,check the points for proper gap and opening and closing and NOT burned or pitted or carboned or gray coated,,,,, ,,,,,Insure the condensor is not bad or shorted or no wires to it are shorted,,,,, ,,,,, ,,,,check to see if voltage is present on coils high side with ignition ON, if not test the switch and any fuses in or out of it or hot wire the coil and see if it fires,,,,, ,,,,, ,test the coils low to distributor side to see if lamp flashes on (points open and coil primary is continuous) and off (points closed) if not, check for shorted wires to points and distributors ground.
You may just need new plugs or points or have a bad shorted condensor or wires or have a bad switch or blown fuse, so get power to the coil at least and check the switches output and input wiring and fuses and/or hot wire the coil and see what happens. Post back or e mail [email protected] with any questions. If you want the Green Magazine articles and/or a 40 wirign diagram, e mail me. Good luck n God Bless ya Gino, let me know what you found, hopefully just a bad switch or wire or bad points or plugs or condensor maybe??? John T Nordhoff in Indiana
