JD40 Dual Touch-o-matic trouble
swf
10-22-2001 17:18:51
I had a leak on my JD40 hydraulic system where the L.H. Control shaft penetrates the pump housing. I removed the levers, quadrant spacer and the splined L.H. Control shaft. I got a new oil seal, but now the L.H. Control shaft does not feel like it is going in far enough and the shaft spins freely. It is bottoming out on something, but doesn't feel like any splines are mating. Anybody know what I've got here and how to get out of it? Something simple sure got complicated all of a sudden.
Richard
10-22-2001 21:54:25
 Re: JD40 Dual Touch-o-matic trouble in reply to swf, 10-22-2001 17:18:51
I had to remove the housing to open up the end to reattach the shaft to the levers leading back to the hydraulic pump.This I still couldn't do ,as I took the outfit to my local Deere dealership where their last two cylinder mechanic pulled out the longest needle nose I've ever seen and had it reattached, 4 minutes and no charge.
