40, 50, 60, 70 Valve Seals
Brad
10-22-2001 14:24:46
Question - Do any of the above use valve stem seals? If so, what type. It's a really long story, but am wondering..
Thanks Brad
Clooney
10-22-2001 14:57:04
 Re: 40, 50, 60, 70 Valve Seals in reply to Brad, 10-22-2001 14:24:46
Brad, no valve seals used.
G Taylor
10-23-2001 09:45:59
 Re: Re: 40, 50, 60, 70 Valve Seals in reply to Clooney, 10-22-2001 14:57:04
That's why rebuilds of two cylinders that reuse old guides & valves burn oil & foul plugs. New valves & guides are cheap. Plus a valve job stays fresh longer with tighter stem to guide clearances.
Putt Putt
10-25-2001 05:28:29
 Re: Re: Re: 40, 50, 60, 70 Valve Seals in reply to G Taylor , 10-23-2001 09:45:59
Are you suggesting that valve seals should be added? Is there room in the spring for automotive, umbrella type seals? Rubber band type? Have you actually done this?
G Taylor
10-25-2001 19:17:09
 Re: Re: Re: Re: 40, 50, 60, 70 Valve Seals in reply to Putt Putt, 10-25-2001 05:28:29
Just new valves & guides to minimize clearance so oil migration & valve/seat wear is reduced. The horizontal valves don't have gravity assist to drag oil down the guides.
