3020 gas runs then dies..
john2510-3020
10-21-2001 17:30:25
i have a 3020 gas powershift(64 modle) that i was useing to mow hay with today and after a little while it started missing and carring on so i shut it off to check spark-plugs. started right up and after i turned on the pto and got it up to speed it died like some one shut the key off. we can get ti to start but after either running for about a minute it dies or when we get it up to about 2000 rpm and let off teh throttle it dies...if anyone could help i would like it alot.
john
Russ
10-22-2001 20:07:28
 Re: 3020 gas runs then dies.. in reply to john2510-3020, 10-21-2001 17:30:25
Check the inlet line to the carb. Some of the fittings into the carb had screens on them that get a moss like substance from the gas over time. Also make sure your condensor is good and the points are gapped correctly and there is lube on the dist shaft to keep wear at a min.If you still need help let me know and I'll do more checking
john2510-3020
10-22-2001 17:37:28
i found out the problem, a bare wire in the distributer was touhing another pice of metal causing it to short out, i found this out after i spent 70 bucks on it. thanks to all who replyde.
john
Don
10-22-2001 06:36:24
Just a thought, remove the distributer cap, where the wires from the condenser "plug" in to the points , check for corosion on the wire ends (will be discolored brass) also check point gap and see if wear point has worn down and closed the points.Don
twopop
10-21-2001 20:11:04
i think the first thing to do is to take the fuel line loose at the carb and see how much flow you have.sounds to me like the line is plugged.
john2510-3020
10-21-2001 20:26:02
 Re: Re: 3020 gas runs then dies.. in reply to twopop, 10-21-2001 20:11:04
twopop, we took the line off but we where in the field and probley didnt take time to look at it very close. it has a fuel filter on it that looks like it has been on it since new so i thought i would get one of those tomorrow along with a new battery. another thing, is the throttle rod supposed to have a spring on it to pull teh govner linkage back, so it doesnt choke it or starve it for fuel? thanks for the help.
john
twopop
10-22-2001 18:49:25
 Re: Re: Re: 3020 gas runs then dies.. in reply to john2510-3020, 10-21-2001 20:26:02
the only spring used on the 3020,is a short spring up at the governor.it is between two levers.
Bill from the north
10-21-2001 22:37:49
If it's not lack of fuel , then it could be a weak condensor or coil
