320 heat shield
Paul
10-21-2001 17:16:17
I just finished rebuilding my 320U and I noticed that it does not have the heat shield that mounts to the rear of the manifold. Is this shield necessary? Is it really important that it be used on a simi retired tractor?
Thanks, Paul
Clooney
10-21-2001 17:35:15
 Re: 320 heat shield in reply to Paul, 10-21-2001 17:16:17
Paul, if that shield wasn't needed Deere wouldn't put it on to begin with. That heat shield was even used on the M. It keeps exhaust heat off the fuel tank & battery. If you only use your tractor for play & don't pull a brush hog, plow or rear blade or only use it in cold weather you probably don't need it. Keep an eye on the fuel tank temperature & if tends to get hot make a shield so the fuel doesn't boil & cause a fire.
Paul
10-22-2001 06:13:23
 Re: Re: 320 heat shield in reply to Clooney, 10-21-2001 17:35:15
Clooney; This tractor has officially retired. It will not be used to plow or bush hog any more. I'm trying to find a used shield but if I can't find one I'll just have to make one. Thanks, Paul
