B governer
Skip
10-20-2001 23:38:09
I just replaced the bearings and seals in the fan shaft or my 51 B, I removed the governer as well and want to set it like it needs to be. It wasn`t right before at all; what is the best way to set the arm on the flyweight shaft for the governer to work right. thanks Skip
Gman
10-21-2001 19:16:32
 Re: B governer in reply to Skip, 10-20-2001 23:38:09
Skip check the pins that hold the weight in place,they get worn and can be sloppy loose and cause you some problems,you can buy new weights thru John Deere if they are loose. When you reinstall govenor shaft assembly,first remove you mag or distr.makes putting the assembly back a little easier,now when you go to install gov. assembly be sure that the weight arms are on the back side of slide assembly,it looks like they go in that slot on slide assembly but they don't they go behind it take my word for it been there done that can't control engine will run away. Once you get the gov.back together you can put your mag or distributor in place. Adjust the linkage from carb throttle to the gov. arm where it is a half a hole short and you should be in business. later Gman
