B rear wheel casting numbers
Murf
10-19-2001 19:53:10
On my 43 B the wheels very similar except for one doesn't have a six bolt ring on the inside. One casting is B1545R the other has JD 2 cast on it. Which one is original?
Clooney
10-20-2001 08:19:24
 Re: B rear wheel casting numbers in reply to Murf, 10-19-2001 19:53:10
Murf, the 1545R wheel is the correct one for S/N B 6000 - B 187388.
Will P
10-19-2001 23:29:19
By 6 bolt ring, you mean the removable hub? You should not have the removable hub. The removable hub came out on tractor #187380. Your center should be one peice with the splines cast in. I have a 43 B also. #141524. Don't pay attention to the serial number list at this site. They are all wrong. 43 B are serial number 136315-149218. Hope this all helps. If not email me.
Will P
