B with no tag
Paul T
10-17-2001 19:44:59
The B I just bought has no serial # but with the parts manual I've got it narrowed down to a 46 or 47. The axle housing has, in addition to the part number, a screwed or rivited tag with a 200 on it. The power lift housing has a 194(?) tag. Is there any way to date these castings or do they all have these? Any other tricks to narrow the possibilities? Thanks in advance.
DP
10-17-2001 20:52:46
 Re: B with no tag in reply to Paul T, 10-17-2001 19:44:59
Russ is correct, also the 47 and later have a single stick transmission with the creeper gears.
Paul T
10-18-2001 19:47:00
 Re: Re: B with no tag in reply to DP, 10-17-2001 20:52:46
It looks like it could still be a 47 even though it has the cast frame - the pressed steel frame didn't start until 201000 and the 47's began at around 191000, so there are a lot of 47's with the cast frame unless Deere skipped all those #'s and started the new redesign at 201,000. This may be as close as I'm going to get - thanks for the replies.
Will P
10-18-2001 21:31:41
 Re: Re: Re: B with no tag in reply to Paul T, 10-18-2001 19:47:00
Cast frames are 43 or 44. Angle iron frames is probably what you mean. Right?
Will P
DP
10-18-2001 21:24:52
Thats right Paul. I know of a cast frame B that is a 47. Its SN is 199888. Worked on it for a friend. It also has rolo-matic front. I suspect it was added to the tractor.
rick
10-18-2001 12:05:06
I have a '49 double stick sn 626081.
DP
10-18-2001 14:00:38
 Re: Re: Re: B with no tag in reply to rick, 10-18-2001 12:05:06
SN 626081 would be an A SN. The A's didn't go to single stick til 1950.
rick
10-19-2001 05:24:11
 Re: Re: Re: Re: B with no tag in reply to DP, 10-18-2001 14:00:38
Thanks.(part of the question didn't post for some
reason and you answered what I intended to post)
ie: when did the A's go single stick. Thanks again
DP
10-19-2001 20:44:02
 Re: Re: Re: Re: Re: B with no tag in reply to rick, 10-19-2001 05:24:11
I've got a 49 A also, SN 637---, and a 52 A SN 702370. Theres a big differance in speeds there.
Russ
10-17-2001 20:00:48
Well it easy to tell the difference between a 46 and 47. The 47 thru 52 will have a pressed steel frame. Also the 1950 thru l952 will have square rear axles. Othere than that pretty tough. Russ
