G power trol
Brian
10-17-2001 17:43:53
rock shaft arms wont stay up
DP
10-17-2001 18:05:06
 Re: G power trol in reply to Brian, 10-17-2001 17:43:53
Several posibilities, but 9 times out of 10 its the gasket between the lift piston pot and the rear housing. I repaired mine a couple weeks ago and was going to replace the leather on the piston while I was there, but its not available anymore. I've been told the gasket between the rear housing, and the powr-trol box will also blow out, but have never had one do that. God luck to you. Don
Brian
10-18-2001 03:51:07
 Re: Re: G power trol in reply to DP, 10-17-2001 18:05:06
i replaced the leather on the piston do you have part number for gasket and i might know where there is a leather cup
DP
10-18-2001 04:22:40
 Re: Re: Re: G power trol in reply to Brian, 10-18-2001 03:51:07
The gasket I am talking about is F 308 R, and the powr-trol gasket is A 1447 R. The F 308 R is the one That most often needs replace.
