D engine experts - need your thoughts
JC
11-28-2003 08:34:23
Problem - The pistons move back so far in the bores that a portion of the rear lip of the oil ring comes out of the bore. The oil ring is 1/4 inch wide and the oil return slot in the ring is quite wide so the scraping surfaces on the ring are quite narrow.
I understand that this is normal on some other models of JD tractors. However, I'm concerned that the motion of the piston under load and the vibration could cause the ring to tip slightly or move back a little further and catch on the edge of the sleeve, breaking the ring or breaking the piston skirt.
Has anyone encountered this problem, and what did you do about it?
Background - A lot of machine shop work has been do to this engine - pistons and rods were reamed to take .005" over-sized piston pins, NOS conn-rod inserts were installed and reamed to fit the crank, the crank throws were built up [badly worn], turned, and ground, the block was sleeved and planed.
Thanks,
JC
Glen in TX
12-02-2003 13:30:40
 Re: D engine experts - need your thoughts in reply to JC, 11-28-2003 08:34:23
Yep, someone re-sleeved yours too short. Have seen this problem several times causing broke pistons and blocks and pulling the sleeves back out and breaking them too. Hard to find someone at a machine shop these days that knows how to do the D blocks much less has the proper equipment to do it. As mentioned by Mike M , you can get someone to face off the back side of the block with a surfacer machine and still use a gasket. We have had the back and front faced off of several D blocks in the past to help increase compression. You can take off 1/8" to 1/4" with no problems but check to see what type and length pistons you have before taking off more than that. I have seen some Ds on LP with 1/2" or so taken off the back side of block. This would be the easiest way other than regrooving the pistons and you will be surprised how much better that D will run with the higher compression. Compression was very low originally on the Ds as most were run on low grade fuels and by using the water valve.
JC
11-29-2003 13:08:56
All,
Thanks for your thoughts. The new sleeves stop at the bottom of the cast iron block metal so a longer sleeve would protrude into the crankcase area a short distance [.100"] which wouldn't be a problem. I've paid to have it sleeved once and it is very expensive up here so I'd rather not pay again.
Some options I'm considering are:
1- Remove the gasket between the block and the case and gain about .020" to .030"
2- Have conn-rod bushings made with the piston pin holes off centre to push the piston slightly ahead at BDC.
3- Have someone machine a wider oil ring groove and make a spacer slightly smaller in diameter than the bore which would keep the oil ring forward on the piston.
4- Have Hastings or someone make an custom oil ring with a wider rear scraping end that would leave some metal in the bore at BDC.
5 - Pray a lot and light it up!
The old rings that came out of the engine had a much narrower oil channel and a lot more metal in contact with the bore. Don't know if they were JD rings of after-market.
Regards to all,
JC
Mike M
11-29-2003 13:39:33
 Re: Re: D engine experts - need your thoughts in reply to JC, 11-29-2003 13:08:56
I don't think I would run it with the rings sticking out that much. One more choice would be to remove the block and have someone machine the gasket surface on the back side this would move it back farther. Just make sure you have enough room up front so the pistons don't pop out there instead.
Mark
11-29-2003 09:14:54
If you're concerned and don't want to resleeve the block with longer sleeves, you might remove the pistons and have a new groove machined in them farther up the piston.
Steve Crum
11-28-2003 21:16:04
Follow the advice you like best but I have a 44 A tractor that someone had sleeved the right cylinder on. When I got the tractor torn down I found the piston skirt below the oil ring, around the oil pump shaft. To make a long story short, I honed the cylinders, put in new rings and a new right piston. I hand rolled the piston to BDC and the oil ring was about a 1/3 of the way out of the bore. Several "experts" looked at it and didn't feel there was a problem. So we fired it so far so good, then we leaned on it some and bang! Another short piston! Not a real problem, only smokes if you start it up, and it's wise to keep the tool box full of clean plugs!
37D
11-28-2003 20:23:45
I don't have any experience here, but it appears that maybe the shop that resleeved your block should have used slightly longer sleeves. I'd not be comfortable if part of the oil ring went beyond the cylinder bore on each revolution. Just my 1&1/2 cents worth.
havvey
11-28-2003 19:07:23
i may not be a d expert but some times machine work can get into thes situations sounds like the stroke is longer i agree with the longer sleeves also look at the block gasket would a thinner one help?
Pat M
11-28-2003 09:29:02
My '26 D was like this also.I had K&K tractor resleeve my block.They make sleeves that are 1/4 to 3/8 longer to correct this problem.
D
11-28-2003 18:38:13
 Re: Re: D engine experts - need your thoughts in reply to Pat M, 11-28-2003 09:29:02
If it ran that way since 1926 wouldn't you think if there was going to be a problem it would have shown up sometime before now?
Pat M
11-30-2003 16:36:15
 Re: Re: Re: D engine experts - need your thoughts in reply to D, 11-28-2003 18:38:13
I would think so.Better to be safe than sorry.My D needed sleeved anyway,so that is the way I did it.
720Deere
11-29-2003 05:51:44
Do you honestly believe that a hard working tractor like a D has run since 1926 without an overhaul?
