2520 flasher unit
Larry
10-16-2001 09:43:52
I have not looked very hard yet but am wondering how you get too the flasher unit or can test to see if good. I have a 2520 with roll guard canopy. I replaced the flashers on canopy but am not getting any power to them. All other lights work. Don't know if flasher is bad or no power to flasher. According to book flasher is located on back side of panel near switches.
Dan S.
10-16-2001 10:56:43
 Re: 2520 flasher unit in reply to Larry, 10-16-2001 09:43:52
The flasher should be a square box,normally black plastic, approximately 1.5 inches per side. it will have two prongs sticking out of it that will be at a 90 degree angle to eachother.. The easiest way to find it is to follow the wires off the light switch.... good luck... finding the problem with flashers can often be a pain..... been there and done that....
Fred Bown
11-27-2002 21:23:27
 Re: Re: 2520 flasher unit in reply to Dan S., 10-16-2001 10:56:43
The flasher is locatedright below you ignition switch behind the panel take one bolt out of your side panel and slide it back on the right side looking ait from the seat and you will see it bolted right in the left corner I had to ask J D to find mine
