Hex Plug In 3020D head removal
BIG JOHN
10-15-2001 04:35:17
Putting in a factory Heater[block] in my pain in the butt deere. plug in extemely tight. can I heat or use Impact gun? uses a 9/16 hex key. Put a water pump in this weekend- whata pain! Part prices are nuts- the small hub for fan broke when removing- 25 bucks? any help guys?
Illinois Red
10-15-2001 20:46:27
 Re: Hex Plug In 3020D head removal in reply to BIG JOHN , 10-15-2001 04:35:17
You can use some heat in moderation. If you try an impact be careful that you don't round the plug. Have you tried to remove the plug after the engine is at operating temperature. When the plug is warm take a punch and hammer and tap on the plug. Try not to distort it though. Good luck. By the way most 10 and 20 series water pumps I have removed the cast hub is stuck too and I often end up breaking them. Good Luck!
