JD unstyled G
Mike Quale
10-14-2001 18:47:00
I am looking for a JD g carb that is ready to bolt on and use...What should I be looking to pay for something like that. Thanks
Gman
10-17-2001 10:20:34
 Re: JD unstyled G in reply to Mike Quale , 10-14-2001 18:47:00
Mike if you are restoing the tractor you need a DLTX-24,if you are pulling you want DLTX-51,if you are highly modified big inches you want a DLTX-51 carb from Robert's Carb service that has been massaged properly and run 3 turns on load jet instead of 1 1/2 my two cents worth Gman
Gman
10-17-2001 10:19:01
Mike if you are restoing the tractor you need a DLTX-24,if you are pulling you want DLTX-51,if you are highly modified big inches you want a carb from Robert's Carb service that has been massaged properly and run 3 turns on load jet instead of 1 1/2 my two cents worth Gman
Leroy
10-14-2001 22:12:50
Big nut G carbs are getting pretty high. Between 200 to 300 dollars would not suprise me.
