Wiring harness for A
Keith
10-14-2001 18:40:12
My dad just bought a wiring harness for his 1949 JD A. There is a wire on it that has a label that says to connect it to the "L" terminal on the voltage regulator but his voltage regulator does not have an "L" terminal. Does anyone know which terminal he can hook it to or does he have the wrong regulator?
Thanks
Jim guarino
09-08-2003 18:17:03
 Re: wiring harness for A in reply to Keith, 10-14-2001 18:40:12
Contact Agri Services for wiring harnesses, switches, and battery cables. They can answer all questions on cutout relays, alternators, and other electrical problems.
Phone 716-937-6618
www.wiringharnesses.com
Clooney
10-14-2001 18:45:52
Keith, that wire (load wire) should hook to the (BAT) terminal on the regulator if the regulator doesn't have an (L) terminal. Leave the BAT wire on there & just hook the (L) wire there also.
