Russ: Yep, a 3020/4020 had a separate lever for each function...one for the 3 pt. rockshaft, and one or more for each remote cylinder. I don't want to confuse you, but the valve I'm referring to IS one of those plugs....you just might have to look REAL close to find the half of the knurled cap that screws off. Could be painted shut....that little knob valve is in there. Reason I think you have one is that on all the early numbered series I've seen that have the outboard cylinder hoses, had that special plug, with the removable cap/selecter valve inside. It's possible that someone had lost the original and replaced it with another/non-selectable plug, but you can get yourself one from a salvage yard, and you'll be much happier. I went out and got my book. If you have the JD Operator's manual (mine is the diesel manual OMR2032) it is under the section called "Adjustments for Breakaway Coupling and Selector Valve Operation". In my parts book it's called AA5724 R, Valve, Assembly, Selector. Have you had this tractor long ? If so, you probably know more about it than anyone else will, but if it's relatively new to you, it might be worth taking a second look at things. You could go to JD and ask to see the illustration of the selector valve assembly. It might make more sense then. Frank-in-Tallahassee 70D // 855
