jdemaris
11-28-2003 06:55:10
Re: 3010 draft bushings in reply to Sammy, 11-27-2003 22:41:27
I guess you have to determine exactly what is causing the failure of the seals. When I worked as a JD mechanic, the "load and depth shaft" seals were a common repair item. Usually, but not always, premature seal failure was due to either a worn shaft, or excessive side play. The steel bushings were rarely replaced. One reason being that they had occasion to come loose in the transmission housing. In that case, there was a repair kit with oversize bushings, but was quite a job to install. Required a lot of specialized equipment that did a line-bore of the trans. housing to an oversize. A JD engineer told me when first assembled at the factory, the bushings are chilled and pressed in. Kind of like a valve seat in a cylinder head. For that reason, we left them alone unless replacement was absolutely necessary. So, drain the transmission. Then, pull the shaft and check for wear on both sides where it rides in the bushings. If worn, replace it. Take extreme care when sliding the shaft through the new load-and-depth seals. When reassembled, check for sideplay. If use enables the shaft to walk back and forth sideways, shim it. I've installed aftermarket bushings with o-rings when requested by a customer. Don't know if they lasted any longer or not, but I doubt it. If buying an aftermarket shaft, don't know what to tell you. The shaft is actually a torsion bar; it's purpose is to sense load on the drawbar, flex accordingly, and send a signal to the hydraulic controls. It it made of high quality steel. In fact, I've had trouble cutting them with a torch. Some sort of high alloy. I come across some aftermarket shafts that are just as high quality, and some that were not. Also pulled out some home-made ones that didn't last at all.
