John Deere 730 throttle handle
Paul
10-11-2001 06:58:35
The throttle handle on my 730 will not stay in position it is fine wide open or at idle. But It will not stay in any other position. Before I go tearing in to it I would like to know if any one has anyidea what the problem is. Thanks Paul
wllarson
10-13-2001 01:09:59
 Re: John Deere 730 throttle handle in reply to Paul, 10-11-2001 06:58:35
On mine, I put a 4in cutting wheel (grind stone) in there. Been there about 15 years. much cheeper.
MIKE HANLEY
10-11-2001 22:44:25
BEFORE YOU TEAR INTO ANYTHING,,,,,FROM THE PULLY SIDE REACH UP UNDER THE HOOD BEHIND THE HANDLE AND FEEL FOR THE SPRING (AS YOU ARE LOOKING AT THE LEVER IT IS THE THEADS OF THE BOLT DEAD CENTER IN THE LEVER) THAT A BOLT GOES THROUGT AND FEEL IF THE SPRING IS NOT TOTALY COMPRESSED..IF IT IS NOT, TAKE A 11/16 I THINK AND TURN IN THE BOLT TO COMPRESS THE SPRING MORE.
IF THAT DOSEN'T WORK THEN REPLACE THE DISCS. IF YOU HAVE TO REPLACE THE DISCS REMOVE THE HOOD AND DASHBOARD AND THEN YOU CAN SEE EVERYTHING AND IT IS EAST TO WORK ON.
MIKE HANLEY
10-11-2001 22:43:06
Larry
10-11-2001 07:24:03
Your problem is fairly easy to fix. You will have to unbolt the throttle lever from the cowl. When you get it off, take off the bolt in the center with the spring on it. You will see the two metal plates with pins. They have friction washers between them. Over time these friction washers wear out. You can get the plates and friction washers from your dealer.
JD Guy in NE
10-11-2001 16:00:23
 Re: Re: John Deere 730 throttle handle in reply to Larry, 10-11-2001 07:24:03
I had this same problem with my 720 but to a lesser degree.. brought it to the attention of my JD mechanic when I had it in the shop to fix the clutch & he fixed it at NO extra charge! The solution is easy but getting to the parts takes some time!
