Cranking an old g
ray
10-10-2001 21:08:37
got a 1938 G with new rings that is pretty hard to crank....how much should I need to run it to get is loosened up enough to be able to crankstart it...also any tips on cranking it? at present time...it seems to hit once and then not again....can I squirt something in the compression pitcocks to help?
Clooney
10-11-2001 15:41:22
 Re: cranking an old g in reply to ray, 10-10-2001 21:08:37
Ray, it depends on what is tight. If just rings it will loosen up as soon as the rings break in, if something else is tight then it will depend on what it is. On the hitting only once it could be a weak coil in the mag or just using the wrong starting procedure. Try different throttle settings, & choke settings to see if that will help. I had an old "A" with a power block that would hit once then require about 20 more flywheel turns with no choke & WOT to start it, with some trial & error I found that one turn with the choke on full then one turn with the choke on 3/4 then the next turn with the choke on 1/2 it would start almost every time.
Dale W.
10-11-2001 09:44:05
Make sure your mag is up to snuff. If it only pops once and doesn't carry over it could be weakness in the mag. Used to crank one of those monsters when I wasn't very big or tough. They are just like Wonder Bread, they build strong muscles. Seriosly, try belt starting, if that works ok, check mag.
