A carb problem update
nigelB
10-08-2001 01:02:58
took my asperin,changed my new champion D-16 to AUTOLITE 388 and low and behold it runs well,the problem new duff plugs. but now a new can off worms as soon as the governor spring leaves contact with the arm she revs right up. have extensavly cleaned the carb through previos explotes,have got 1/2 hole overlap on rod,tryed to control via load,idle ajustment down to 1/2 and 1,also rebuilt governor in the past(weight wear,pins ect)pull on governor arm and it pulls you back. what about mag advance,float height or over sensative rod length. getting there nigelB
Gman
10-08-2001 19:53:12
 Re: A carb problem update in reply to nigelB, 10-08-2001 01:02:58
NigelB when you rebuilt the govenor,did you put the weight arms in slot on slide,if you did they are in the wrong place,the arms on the weights goes behind the slide assembly.been there done that and it did just as you descibed rev up uncontrolable put the weights behind the slide assemly cured my problem. Gman
lynn
10-08-2001 16:25:23
i found that if everything is in working order and it won't idle down at high idle i lenghten the throttle rod where it goes in the hole of the carb without the 1/2 hole that it calls for seems like that with a little wear here and there the weights don't push the throttle rod far enough forward to idle it down at high idle lynn
