Pete
10-07-2001 17:39:28
Clooney, Thanks for the help you gave Dad yesterday on the 70 clutch, unfortunately we are still stumped. The fork is in the operating groove, and all seems assembled correctly, here are the symptoms; in order to be able to have the clutch engage positively with out slipping, we have to adjust the adjusters down so far that the clutch simply will not disengage. When the clutch is adjusted this tightly, you cannot shift. It seems that there is not a full range of movement. The dogs, toggles, pins, adjusting bolts, springs, fiber discs, and pressure plate are all new. Three things come to mind; the new toggles were about 1/16" longer than the old ones, I figured this was due to wear, and the toggles had a hole(grease retainer?) in one end, none of my manuals specified which way the go, so I figured that the end that goes in the cup on the dogs would get more movement, filled the holes with Moly G and put them in that way. Could thay be in backward, and would that cause a problem? Would the extra length cause a problem. One other possibility that I wonder about; could the drive gear not be pressed on far enough? I haven't seen any measurement to check this, but it appears to be in the same place it was before we pulled it off ( it is pressed on as far as the 75 ton air press would press it,) so i guess I'm screwed if this is the problem. I appreciate the help, I am about to throw up my hands for the first time on this tractor, and take it to a repair shop, problem is this, even the techs at our local JD dealer give ya that "thousand yard stare" when you mention having them work on a 2 cylinder. I work at a Case dealer who services just about anything that gets brought in, our svc. mgr said "Pete if you can't figure it out, none of our guys will be able to, go to a Deere dealer!
