G live Hydraulics
Gman
10-07-2001 04:52:46
Winter project--still trying to get the live hydr. to work on my "G" before next year. Question when I put the remote pump on I removed the idler in pto pump and installed spacer between powertrol and rockshaft housing blocking off port that goes down to pto pump,should I have left idler in place my theory is with idler in place it would help provide sucion for G.H. pump Clooney you and WTW have a lot of experience with these old tractors got any ideas,I been greased up along time fooling with this thing,seals are good. Gman
Clooney
10-07-2001 05:10:25
 Re: G live Hydraulics in reply to Gman, 10-07-2001 04:52:46
Gman, you did the correct thing by removing that idler gear, if you don't it will over pressure the original pump with the PTO turning because of the block-off plate & lug the engine down. There is a service bulletin on the live hyd conversion from Deere, the only problem is I can't find it at this moment. If I do I will send it to you.
Gman
10-08-2001 19:40:16
 Re: Re: G live Hydraulics in reply to Clooney, 10-07-2001 05:10:25
Thanks Clooney I been fooling with this thing for two years off and on,just about to the point to just revert back to the shaft pummp,will be inconvient but I will be able to at least raise my plows.It works fine sometimes,just load her up and go to a plow day,it wouldn't work for love nor money,so any assistance will be apreciated Gman
Will P
10-07-2001 19:41:23
Hey, could you send the bulletin to me too. I want to put the pump on my 43A that I have that has powerlift.
Thanks, Will P.
