720 countershaft end play
Russ
11-27-2003 17:12:02
My 720d has about 10 thou end play.I checked the bearings and they seemed ok .There is no more shims left in the bearing housing.Could it be the thrust washer. Will 10 thousand be too much?Thanks for any info. Russ
Clooney
11-27-2003 18:08:38
 Re: 720 countershaft end play in reply to Russ, 11-27-2003 17:12:02
Russ, .010" end play is plenty high, especially for a diesel. I usually set the countershaft end play as close to .001" as I can.. If those bearings are very loose they tend to rattle around with the engine firing pulses & that will brinell the bearings.
~The extra end play you have is probably caused by worn bearings even though they don't look bad, or one of the bearing races has spun in the case or housing & worn it's retaining ring or bottom of the bearing cup bore... That thrust washer shouldn't be a problem as it doesn't spin & should be pinched tight by the R/H bearing inner race.
~You have a few choices, if the bearings still look good you can put a shim between the R/H bearing outer race & back of it's housing bore, or pull the R/H bearing from the countershaft & place a .020"-.030" shim between it & the thrust washer [that will allow room to add shims back under the R/H housing]. Or you can push the entire shaft farther to the right with a smaller snap ring between the case snap ring & the L/H bearing race.. Probably the best place is between the R/H bearing & thrust washer.. If you go that route be careful pressing the R/H bearing & thrust washer off as that hardened thrust washer breaks easily... Last time I needed one Deere didn't have any so I had to by a used one].. The easiest would be behind the R/H bearing outer cup but that would probably require a new cup as you probably can't get the old one out without damage..
~It will probably run for quite a while with .010" end play but as long as you are right there you might as well do it right & not have to worry about it getting worse & tearing up those expensive bearings, gears & shafts..
[email protected]
Russ
11-27-2003 18:30:26
 Re: Re: 720 countershaft end play in reply to Clooney , 11-27-2003 18:08:38
Thanks Clooney
