70D timing marks,need help
travis
11-27-2003 15:58:19
I had to change the crank shaft in my 70,I lined the marks up on the crank shaft gear to the gear above it and also lined up with the cam shaft gear,everything looks to be right there,what I was wondering is when I put the gover back on is there any timing marks that I have to line up there?thanks for any help
Clooney
11-28-2003 04:41:52
 Re: 70D timing marks,need help in reply to travis, 11-27-2003 15:58:19
Travis, Frank has you covered on the cam/crank timing..
~I will just add a couple other points of interest...
~When installing the timing cover don't forget the thrust washer on the hydraulic pump shaft [that's easily left off if not careful]..
~When installing the thrust washer cover be sure to install it correctly so the oil drain is on the bottom. The early ones say TOP. If installed incorrectly you will have a big oil leak. Also center the cover on the crankshaft using .003" shim stock so it allows the crankshaft to run centered.
[email protected]
BJ
11-27-2003 16:26:59
Yes as you have found out the crankshaft to camshaft marks are on the inside of the crankcase where as the camshaft to governor gear marks are on the outside you have to take the left hand bearing cover (4 bolts) off from the governor housing in order to see these marks
F-I-T
11-27-2003 16:42:44
 Re: Re: 70D timing marks,need help in reply to BJ, 11-27-2003 16:26:59
BJ:
This is a diesel he's talking about right? All the timing marks are on the sides of the gears facing outward, inside the timing cover, but outside the crankcase.
Travis:
Yes, it sounds like you have got them all lined up. The crank gear mark to the outside teeth mark of the double gear above it, then the inner gear of the double gear to the cam gear. A to B and B to C.
There is no outside timing do perform. The flywheel will install in the proper "V" mark, and that puts it "in time" with crank and gears. That you can use the pump timing marks on the outer edge of the flywheel if needed to time the pumps. Be sure to use a proper sealant on the timing gear cover gasket. It's crappy if it leaks!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
travis
11-27-2003 19:16:33
 Re: Re: Re: 70D timing marks,need help in reply to F-I-T, 11-27-2003 16:42:44
How do I know where to put the governor gear on the cam shaft gear to have it timed for the fuel pump?is there any marks on the governor gear to line up on the cam shaft gear?thanks
F-I-T
11-27-2003 20:01:11
 Re: Re: Re: Re: 70D timing marks,need help in reply to travis, 11-27-2003 19:16:33
Travis:
You don't have to time the fuel pump. The cam turns the governor shaft, and the governor shaft turns the fuel transfer pump. It doesn't care where it is when it starts.
The pumps you DO time are the two under the cover on top of the block. They must be timed to inject the fuel on time into the combustion chambers. You won't have to do this if you didn't disturb the settings with your repair.
Frank
travis
11-27-2003 20:23:12
 Re: Re: Re: Re: Re: 70D timing marks,need help in reply to F-I-T, 11-27-2003 20:01:11
I did not take the cam out,just the crank shaft was changed and I had to take the gears off the left side,I put them back on as I took them off,so I have it right so far?Thanks
F-I-T
11-28-2003 05:42:00
 Re: Re: Re: Re: Re: Re: 70D timing marks,need help in reply to travis, 11-27-2003 20:23:12
Travis:
Yup, sounds good. You should not have disturbed any of the top end, like pump timing. As ong as you have the crank to double gear, double gear to cam.
Frank
BJ
11-27-2003 17:25:20
Oh my bad didn't notice the D in his post guess I better take a nap
