3020 gas powershift
john2510-3020
10-04-2001 17:38:25
i need help on a 64 gas 3020 poweshift. we had the tractor rebuilt about a month ago but the tractor would never stay in park unless you turned the wheels up hill. we never had this problem befroe so waht happend? i get on and off the tractor quit a bit and we have some pretty bad hills so i dont want to take the chance and get run over....can anyone help me? thanks in advance.
john
WTW
10-05-2001 08:01:01
 Re: 3020 gas powershift in reply to john2510-3020, 10-04-2001 17:38:25
Sounds like that the tractor is not getting into park all the way and when resistance is applied to it, it is forcing itself out of park. What can happen and is fairly common is when work is performed on tractors at dealerships it is common to steam clean or power wash them off, moisture from cleaning will get into the park cable resulting in rust causing cable to drag. If the cable has to much drag on it, the pull spring under the dash may be stretching prematurely not allowing full movement or stroke of the park cable resulting not getting the park in a full engage latched mode. Remove the dash cowl and check to see if cable is moving it full travel, also check that the park cable clevis pin is in the correct hole in the control arm of the park lever mechanism. The main thing to check whatever the cause is that the cable is traveling far enough to rotate the arm on the side of transmission to a full forward (engaged) position. If arm on the side of the transmission is being rotated full forward and tractor is still moving in park your problem is inside the transmission. The top transmission cover will have to be removed to see what is wrong. You may find that the roller has come off the park pawl arm and will need to be fished from the bottom and reinstalled with new retaining hardware. See what you learn. Good Luck, Dave W.
Oaktree
10-05-2001 18:49:53
 Re: Re: 3020 gas powershift in reply to WTW, 10-05-2001 08:01:01
Again WTW right on the mark. I'd Like to add that the cable turns a cam inside the Trans case. when one goes out of park the lobe lifts the park pawl. When you go into park the lobe goes down and a inner spring pulls the pawl down. The spring under the dash is foe when there is too much pressure on the pawl like parked on a hill. It allows on to put the trans in "gear". With the pawl engaged. If you are pointed downhill put the trans in reverse and the pawl will be released by the spring tension under the dash.
john2510-3020
10-05-2001 17:15:33
thanks guys i will check it out this weekend if given teh chance. hope its not in the tranny and its just the linkage.
Bob
10-04-2001 21:51:18
You might need to look into adjusting your linkage first. Then if it still doesn't work properly look at the shifter under the dash for excessive wear. I would look at the transmission last. If your John Deere dealer did the repair then they should warranty their work. Most parts carry a 90 day warranty through Deere anyway. I would think that having a transmission rebuilt would mean that park should work properly also. Good luck.
