Fireseal for Manifold Repair.
AWB
11-27-2003 15:45:15
Has anyone out there had any experience with the product called Fireseal (R) to Repair cracks and holes in exaust manifolds? Thanks.
AWB
11-29-2003 05:24:10
 Re: Fireseal for Manifold Repair. in reply to AWB, 11-27-2003 15:45:15
Thanks, Joe for the information on the use of Fireseal on manifold repair.
Joe M
11-28-2003 18:09:49
If you're talking about the one sold by por-15, I have used it. It has worked great on a manifold on one of my AC tractors that was rusted through. Getting it cleaned up well enough
for it to stick is the hardest part! I removed mine and bead blasted it inside and out, and then
opened up the bad area with a grinder a small amount,then blasted it again through the enlargement I made. The only drawback I had was that it's kinda runny when it's first mixed, it was better to have the manifold off so you could turn it so that it would sty were it was needed. Then you let it sit for 48 hours, then I slow cured mine in the oven for a couple of hours while the wife was out. Works great ! (so far, has only been three months of use, but I'd try it before buying a new manifold !
