JD Model M 1951
Gary Tarr
10-04-2001 11:24:55
Does anyone have a copy of the 6 volt wiring for this?
I redone some of the wiring , but it still will not start on its own? should this be a possitive or negetive ground?
I am trying to work on this, its my Father-In Laws and I don't know anything about these
After I rewired the bad wiring it would turn over a little ,but didn't start.
We can pull it and with a little pull it starts and runs good and shows a good charge
But, when i tried to turn it over and start it the starter smoked a little and the negitive cable got hot?
Help!!
Thanks,
Gary
Clooney
10-04-2001 14:03:31
 Re: JD Model M 1951 in reply to Gary Tarr, 10-04-2001 11:24:55
third party image
Gary, it sounds like either your starter is bad or there is a bad ground in the starting circuit or the battery cables are too small of a gage (small 12 volt cables from the local auto or tractor parts store aren't heavy enough gage for a 6 volt system). Your system is positive ground.
Tugboat
10-04-2001 18:03:00
 Re: Re: JD Model M 1951 in reply to Clooney, 10-04-2001 14:03:31
Clooney; I helped myself to a copy also. I assume this diagram would apply to a 320 also.
Thanks; Tugboat
Clooney [1st part]
10-04-2001 18:39:18
 Re: Re: Re: JD Model M 1951 in reply to Tugboat, 10-04-2001 18:03:00
third party image
Tugboat, I don't have a wire print on the 320 but a 40 is real close.
Clooney [2nd part]
10-04-2001 18:41:15
 Re: Re: Re: Re: JD Model M 1951 in reply to Clooney [1st part], 10-04-2001 18:39:18
third party image
second part.
