4640 clutch
Oaktree
10-03-2001 17:30:47
What are the symptoms that a clutch for a quad range 4640 that the clutch needs replaced?
twopop
10-03-2001 20:26:14
 Re: 4640 clutch in reply to Oaktree, 10-03-2001 17:30:47
the main symptom would be clutch slippage in any gear,however,the clutch is engaged with hydraulic pressure.the lack of pressure may cause clutch slippage.a shop manual will tell you how to check the pressure.On the left side of the tractor under the cab there is a hyd.valve housing.in this housing there will be a port that has clutch cast into it.install a 200 psi gauge and check pressure with engine running at 1700rpm.check with two speed lever in low and high position.you should maintain 145 psi.if 145psi is present in low range but drops off in high range ,you have a leak in the two speed planetary trans.hope this helps
Oaktree
10-04-2001 16:48:42
 Re: Re: 4640 clutch in reply to twopop, 10-03-2001 20:26:14
What concerns me is that there is very little pedal movement between fully out and fully engaged. There isn't any slippage once engaged.
PI
10-04-2001 20:08:20
 Re: Re: Re: 4640 clutch in reply to Oaktree, 10-04-2001 16:48:42
There's a spring in the clutch valve that breaks & causes the clutch to be too aggressive-actually there's 2 springs, only the short one seems to ever break-all 30 & 40 series Quads had this problem on a fairly regular basis.
Oaktree :Thanks
10-05-2001 18:55:47
 Re: Re: Re: Re: 4640 clutch in reply to PI, 10-04-2001 20:08:20
Thanks
twopop
10-04-2001 17:11:51
as best as i remember,thats the way they are.all the cutch pedal controls is a hyd.valve that controls oil flow.
