John Deere Green info on paint?
Guy
10-03-2001 11:42:17
This has likely been addressed 100 times in the past, but I am somewhat new to all this so I need to ask. I am told there are different variations of JD green paint including an "automotive" green which is not the correct shade (supposedly). I would like to use a combination of paints including spray cans and gallon cans as I will be brushing,spraying via aerosol as well as through a gun (key parts like the hood and other tin, etc.) Can anyone tell me what's a good "correct" paint that will match up well whether I buy it in a spray can or gallon can? Maybe this is a dumb question, but I just want to be sure. I want to use a good quality paint and must be the correct shade. I know the local JD dealer has some paint which I assume is correct, but seems a little pricey, any comparable paint of good quality that I can buy? Any info is appreciated. Thanks in advance.
Pete
10-03-2001 18:40:36
 Re: John Deere Green info on paint? in reply to Guy, 10-03-2001 11:42:17
Guy, best luck we have had is JD paint (we use Classic for our 2 cyl tractors, but Ag is good too) with a wet look hardner. The spray bombs match well,, and it is readilly available. Make sure you use JD yellow though, the Tisco, and central tractor yellow is horribly pale and fades real fast! Pete
HMan
10-03-2001 17:56:16
Guy, Clooney has some good points. Hear's my .02. I like the "slow" drying JD paint in AG green. with a little wet look hardener. You can use the aerosol behind flywheels,inside frame rails ,etc. while assembling the tractor. JD's aerosols match their spray paint well. HMan
Larry
10-03-2001 17:44:26
I use the John Deere green ag paint from my local dealer. I think it is the best paint you can buy for the money. I also add dupont Du Lux hardener as it makes the paint shine better and also has a great resistance to fading. Here in Montana the dealer gets about $36 for a gallon of their paint and $22 for the primer. The Du Lux 77s costs another $14 from the auto parts store, and then the John Deere thinner is $13 a gallon. Takes me about a gallon and half to paint two coats on average. I just can't seem to get by with one gallon.
BMeyer
10-03-2001 17:39:47
Guy...My vote would be JD classic green for the two cylinders. I recently painted a 420 with the classic and it looks good. I added NAPA hardener when spraying with a gun and it has a very nice shine. (I'm sure it didn't shine this good when it was new.) JD paint has a tendancy of fading over time loosing it's shine. The hardener is supposed to help prevent that from happening so fast.
Just this afternoon, I touched up a couple springs using their aerosol can and the color matched exactly.
I've not used the TSC paint but have read some things about it that convinced me to pay alittle extra for the JD paint. You can use the "search" feature on this site and type in "paint". You'll have lots to read.
Hope this helps.
luke
10-03-2001 12:38:14
Guy, for the older tractors(most 2cylinders) "Classic JD Green" is supposed to be the right color. However, the tractors I have painted have both classic green and regular green and I can't tell much difference. The main thing is make sure it is JD brand and not TSC or something like that. It WILL NOT match identicle to the real JD green. Hope this helps. Luke
Clooney (first part, see next post)
10-03-2001 13:00:03
 Re: Re: John Deere Green info on paint? in reply to luke, 10-03-2001 12:38:14
Sorry luke I meant to post this to Guy.
Clooney
10-03-2001 12:58:22
Luke, none of the J.D. paint is exactly the correct color. There seems to be 2 J.D. colors to choose from at this point in time (Classic green) & (AG green). The classic green was developed for the lawn & garden end but has become accepted as somewhat correct for the 2 cylinder J.D.s. The AG green has been used for 2 cylinder restoration for many years now & is about as correct as the classic. The color is pretty close with (in my estimation) the AG green being a little darker & a little deeper green. If they aren't next to each other you can't tell the difference. Use which ever you want with the idea of having it easy to get in the containers you need. I have seen many originals & can't tell you what the exact color is because of memory fade, paint fade & different ingredients used now, to me J.D. green is J.D. green (from any distance).
