Help with transmission
model H
tom
10-03-2001 09:26:15
Planning on reassembling the transmission of my 41 H with gears out of another H. any help with this task would be great . Thanks in advance.
HMan
10-03-2001 17:47:01
 Re: Help with transmission - model H in reply to tom, 10-03-2001 09:26:15
Tom, There's really no big secret on the H tranny. The I&T is about the best source. You need to pull the belt pulley/clutch, then reduction cover and gear. Bolt a piece of 3" channel iron (about 4'long)under the drawbar frame and set the tractor on jackstands. Remove the wheels then the axle housings where they bolt to the main case. Then you can roll out the ring gear. Now you're ready to get at the gears. Those little trannys are really simple, I guess the gears are really the easy part. The only really tricky part is the spring loaded dogs on the shifting collars. But you can get it. Replace bearings as needed. While you have it down put bearings in the belt pulley. Do not put it back together without replacing the inner axle seals and also check the brakes and replace if needed. You don't want to go back in for these at a later date. Hope this helps you, HMan
