520 Fluids Transmission/Hydr. ?
clayton
10-03-2001 08:37:54
I need help with the proper fluids to put in my 520. I have the original service with the tractor. In changing the transmission fluid it asks to use a flushing agent following the draining of the fluid. What weight of oil do I put in the Transmission? What weight oil do I put in the First Reduction gear? And what weight of oil do I put in for the power-trol?
Do you use a flushing agent when changing the transmission fluid?
Any comments are appreciated.
Thanks for the help.
richard
10-07-2001 06:04:37
 Re: 520 Fluids Transmission/Hydr. ? in reply to clayton, 10-03-2001 08:37:54
It should be in your manual what fluids to use.If you dont have a manual I will check mine.I just bought A 520 and was wondering if its supposed to be negative ground? I'm also looking for a wiring diagram.Mine has a narrow front with a model 50 loader.I just took the loader off and put new rubber on back.Will be putting in garage for winter to fix some things.Needs exhaust work.
