Is it a 4B or #52 Plow?
Tom Mooney
10-03-2001 06:24:34
I just acquired a two bottom trip plow on steel. How can I tell what model I have? It has the words "john deere" followed by the numbers 612 or maybe 613 stamped on the top of each main arm back near the downward curve. I know Deere made a model 4B and a #52 about this vintage. Any help would be appreciated. Thanks in advance.
Will P
10-03-2001 16:14:50
 Re: Is it a 4B or #52 Plow? in reply to Tom Mooney, 10-03-2001 06:24:34
#52, they were built from 35 to the late 40's. The brackets will date it a little. Send me some pictures.
Will P
ET
10-03-2001 11:04:04
If you measure from the point of the plow share up to the frame a model 4B will have 23 inches of clearance. The model 52 will be a little less trash clearance.
Mike Aylward
10-03-2001 08:04:05
Tom, with those beam numbers your plow is a model 52. Hope this helps. Mike
Larry
10-03-2001 07:02:07
I don't have my plow books here today but generally if your land wheel is same size as furrow wheel it is a #52. If land wheel is larger then a 4B. There are many other models also but those 2 are most common.
