JD 2020 Shifting
JD2020
10-02-2001 10:07:23
I have a JD 2020. When switching from Park or Neutral into any gear, many times it will grind the gears. The clutch is pushed in all the way. It's kind of like it takes too long for the gears to stop turning or that the clutch does not quite disengage the trans. If I hold the clutch in for maybe 10 seconds, it might shift fine. Is there something that needs adjusted or is this a bigger problem?
Charlie
10-03-2001 10:36:37
 Re: JD 2020 Shifting in reply to JD2020, 10-02-2001 10:07:23
I had the same problem on my 1520. I replaced the snubber pads which did help some. Its a lot of work to replace these because you have to split the tractor to get to them. I am not sure that it was worth the effort.
DuaneD
10-02-2001 18:59:30
My 2020 does the same thing. I'm no expert mechanic, but I find that patience when shifting works best. Make sure you are completely stopped before shifting, and if the machine is idling, as you said, push in the clutch for a few seconds before shifting.
If someone knows better and what you describe is the symptom of a bigger problem, I'd like to hear it too.
Robert
10-02-2001 20:35:08
 Re: Re: JD 2020 Shifting in reply to DuaneD, 10-02-2001 18:59:30
It could be the clutch dragging;maybe a little bit of oil got on it,the clutch disk or presure plate may be warped preventing a complete release.
The other possiblity is the transmission uses snubbers (spring loaded friction pads) to slow the countershaft that may be worn out.
