Model 40 Camshaft Timing
Bill Irsik
10-02-2001 08:14:48
I'm rebuilding the engine in a 1953 Model 40. There are no camshaft to crankshaft timing marks. I'm curious if anyone knows of any reference marks. I have timing specs as far as camshaft degreeing.
Magoo
10-03-2001 11:02:27
 Re: Model 40 Camshaft Timing in reply to Bill Irsik, 10-02-2001 08:14:48
Check oout Told's tractor pages, www.jd40.com
he is the 40's man.
My 1955 420 has markse of both gears, a little hard to see.
Bill Irsik
10-03-2001 12:14:02
 Re: Re: Model 40 Camshaft Timing in reply to Magoo, 10-03-2001 11:02:27
Would you believe after reading another post on this forum about how hard these marks are to find, I did some scraping with some emery cloth and to my delight they were there. The mark on the crank is referenced with the key way. The mark on the cam gear is straight across from the hydralic pump drive dow. Mystery solved I am going back together with this beast. Once done I have a 1937 unstyled D I will be restoring. Thanks to Magoo for responding.
